Was du brauchst
Unscrew the six screws from the pad.
Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
Reconnect the new cable to the domino.
Then replace the cable, the sheath must arrive between the two pads and the sleeve must be positioned in its housing.
Reposition the part, then lock the engine with a screwdriver to screw.
Put the tray back on and screw the screws.
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
