Einleitung
This guide will show you how to replace the base plate on your tool
Was du brauchst
Using a screwdriver or screwdriver, unscrew and open the device.
Unlock the tray by lifting the lever.
Tighten until it's good. To help you, you can replace the lid of the machine to best adjust.
Fast fertig!
The reassemble follow guide through
Abschluss
fr en
100%
Hier starten ›
