Zum Hauptinhalt wechseln
Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement
Was du brauchst
  1. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement, Unplug: Schritt 1, Bild 1 von 1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 2, Bild 1 von 2 Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 2, Bild 2 von 2
    • Remove the side handle and the protective cover.
  3. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 3, Bild 1 von 2 Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the 4 screws to open the machine.
  4. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 4, Bild 1 von 1
    • Remove the paddle switch for better access.
    • Remove the two pods.
    • Relax the blade springs.
  5. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 7, Bild 1 von 1
    • Relax the carbons.
  6. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the four head screws and remove the motor.
  7. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 9, Bild 1 von 1
    • Put the new motor back.
  8. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 10, Bild 1 von 1
    • Re-grease and replace gear case.
  9. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 11, Bild 1 von 2 Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 11, Bild 2 von 2
    • Replace the carbons.
  10. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 12, Bild 1 von 3 Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 12, Bild 2 von 3 Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 12, Bild 3 von 3
    • Then reconnect the carbons.
  11. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 13, Bild 1 von 1
    • Replace the paddle switch.
  12. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 14, Bild 1 von 1
    • Tighten the 4 screws to close.
  13. Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 15, Bild 1 von 2 Dexter 800W Corded Angle Grinder - 800AG2-125.5 Motor Replacement: Schritt 15, Bild 2 von 2
    • Replace the outer flange, protective cover and side handle.
Abschluss
By the end of the guide you will have replaced the motor in your device.
To reassemble perform the steps in reverse.
3 weitere Personen haben diese Anleitung absolviert.
fr en
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Leroy Merlin Mitglied von Leroy Merlin
Community
39 Mitglieder
250 Anleitungen geschrieben
2 Kommentare zur Anleitung
Bonjour, Auriez vous la référence du roulement qui se trouve du côté des charbons s'il vous plait ?
Merci.
Riviere Guillaume - Antwort Teilen
J'ai la même demande, merci.
A moins qu'il faille remplacer la totalité du bloc moteur ?
Merci.
Philippe Illinger - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 34
Insgesamt: 2,158
