Einleitung
This tutorial shows you the change of only one carbon, to change the second you just have to follow the same method.
Was du brauchst
Replace the new carbon brushes in their housing.
When putting the new carbon back, check that the legs of the carbons are well located in the rectangles.
you will have replace the carbon by the end of the guide
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Ein Kommentar
Bonjour c’est bien mais sur quel site avez-vous trouvé les charbons?
