Einleitung
By the end of they guide you will have adjusted the height of the device
Was du brauchst
Finally put each piece back in order.
To tighten, simply replace the tray at the bottom and hand tighten the nut.
With the lever, take the nut and put it in the locked position without effort
Fast fertig!
to reassemble perform the steps in reverse order.
Abschluss
fr en
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
