Einleitung
This tutorial shows you how to change one charcoal, to change the second you just have to follow the same method.
Was du brauchst
Using a screwdriver unscrew and open the unit.
Unlock the tray by lifting the lever.
Press lightly on the paw with a point to make it come out.
Remove the coal by pressing on it.
Lift the small tab from the inside by pressing on it, it should stick out slightly.
Put the new coal in the coal holder.
Pull on the charcoal to make it stick out.
Compress the carbon holder and put it back in its housing.
The coal holder must be in the right direction, the small line is at the end.
Eine weitere Person hat diese Anleitung absolviert.
100%
Hier starten ›
