Zum Hauptinhalt wechseln
Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
Was du brauchst
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: Schritt 1, Bild 1 von 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 2, Bild 1 von 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 2, Bild 2 von 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 2, Bild 3 von 3
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 3, Bild 1 von 2 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 3, Bild 2 von 2
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 4, Bild 1 von 1
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 5, Bild 1 von 1
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 6, Bild 1 von 1
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 8, Bild 1 von 1
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 9, Bild 1 von 1
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 11, Bild 1 von 1
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 12, Bild 1 von 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 12, Bild 2 von 3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: Schritt 12, Bild 3 von 3
    • Replace the tip, strip and handle.
Ziellinie
fr en
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Céline Chemineau
16.608 Reputation
95 Anleitungen geschrieben
Leroy Merlin Mitglied von Leroy Merlin
Community
37 Mitglieder
239 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 331
