Was du brauchst
Remove the screws from the hull to have access inside and allow the coals to be blocked.
Unscrew the two screws from the switch to extract the second cable.
To extract the cables you can use a clamp.
Fast fertig!
Ziellinie
fr en
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
