Einleitung
This guide will show you how to replace the motor in your tool .
Was du brauchst
Unscrew the first screw of the pad.
Then unscrew the four remaining screws and pull up to remove it.
Finally, remove the screws located on the hull of the device.
Trap the two carbons to be able to take out the rotor. With a screwdriver to lift them up, then with another screwdriver press the tab.
Lift the carbons and with the other tip of the screwdriver, come twist the small paw.
Then remove the carbon.
Use a soldering iron to weld the component's rotor.
De-solder at the location of the wires.
Then remove the wires one by one to remove the component.
Return the new component to its location.
Then unfold the four threads in their place.
Replace the rotor in its housing.
Unlock the carbons.
Replace the cable, the sheath must arrive between the two studs and the sleeve must be positioned in its housing.
Replace the hull of the sander by being careful to properly position the stabilisers in their housing.
Replace the pad by positioning it perfectly in the tips.
Screw the four screws.
Then the last screw. Finally, put the joint back in its place.
To reassemble follow the steps in reverse.
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
