Was du brauchst
Unscrew the six screws of the pad.
Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
Unscrew the domino screws to disconnect the cables.
Use a clamp to extract the cables.
Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
Replace the new engine.
Remember to recover the small washer at the end of the old piece.
Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
Reposition the part, then lock the engine with a screwdriver to screw.
Put the tray back on and screw the screws.
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
