Zum Hauptinhalt wechseln
Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable
Was du brauchst
    1. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable, Unplug: Schritt 1, Bild 1 von 1
      • Before starting, remember to disconnect the outlet from the mains.
      Frag FixBot
      Kommentar hinzufügen
    2. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 2, Bild 1 von 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 2, Bild 2 von 2
      • Remove the side handle and the protective cover.
      Frag FixBot
    3. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 3, Bild 1 von 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 3, Bild 2 von 2
      • Unscrew the 4 screws to open the machine.
      Frag FixBot
    4. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 4, Bild 1 von 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 4, Bild 2 von 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 4, Bild 3 von 3
      • Remove the switch from his housing in order to have access to it.
      • Unscrew the two screws to disconnect the cables.
      Frag FixBot
    5. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 5, Bild 1 von 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 5, Bild 2 von 3 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 5, Bild 3 von 3
      • Replace the cable and reconnect the cables to the switch.
      • Be careful to put the sheath back between the two studs.
      Frag FixBot
    6. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 6, Bild 1 von 1
      • Before closing, check that no cables are blocked.
      • Screw the 4 screws to close.
      Frag FixBot
    7. Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 7, Bild 1 von 2 Dexter wire angle grinder 800W - 800AG2-125.5 Replacement power cable: Schritt 7, Bild 2 von 2
      • Replace the external flange, the protective cover and the side handle.
      Frag FixBot
Ziellinie
fr en
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Leroy Merlin Mitglied von Leroy Merlin
Community
39 Mitglieder
251 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 506
