Zum Hauptinhalt wechseln
Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement
Was du brauchst
  1. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement, Unplug: Schritt 1, Bild 1 von 1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 2, Bild 1 von 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 2, Bild 2 von 2
    • Remove the side handle and the protective cover.
  3. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 3, Bild 1 von 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the 4 screws to open the machine.
  4. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 4, Bild 1 von 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 4, Bild 2 von 2
    • Remove the switch from his housing in order to have access to it.
  5. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 5, Bild 1 von 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the two screws.
  6. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 6, Bild 1 von 3 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 6, Bild 2 von 3 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 6, Bild 3 von 3
    • Replace the component.
    • Tighten the screws well after putting the cables back on.
  7. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 7, Bild 1 von 1
    • Before closing, check that no cables are blocked.
    • Screw the 4 screws to close.
  8. Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 8, Bild 1 von 2 Dexter wire angle grinder 800W - 800AG2-125.5 Switch Replacement: Schritt 8, Bild 2 von 2
    • Replace the external flange, the protective cover and the side handle.
Ziellinie
fr en
100%
HelloMacOS hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Leroy Merlin Mitglied von Leroy Merlin
Community
39 Mitglieder
250 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 799
