Einleitung
This guide will cover the disassembly and replacement of the battery for the Digiland DL700D. The battery is attached to the mainboard by soldered wires, so some soldering will be required. We recommend reviewing iFixit's soldering guide here.
  1. Remove the device's back cover using the plastic opening tool. Remove the device's back cover using the plastic opening tool. Remove the device's back cover using the plastic opening tool.
    • Remove the device's back cover using the plastic opening tool.
  2. Remove the three pieces of adhesive placed over the edges of the battery. Remove the three pieces of adhesive placed over the edges of the battery. Remove the three pieces of adhesive placed over the edges of the battery.
    • Remove the three pieces of adhesive placed over the edges of the battery.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the wifi antenna from the bottom of the battery.
    • Remove the wifi antenna from the bottom of the battery.
  5. Heat up the soldering iron, proceed to desolder and remove the battery connections. Heat up the soldering iron, proceed to desolder and remove the battery connections. Heat up the soldering iron, proceed to desolder and remove the battery connections.
    • Heat up the soldering iron, proceed to desolder and remove the battery connections.
  6. Remove the battery from the casing using a nylon spudger. Be careful not to puncture the battery casing. Carefully peel the battery free from the casing.
    • Remove the battery from the casing using a nylon spudger.
    • Be careful not to puncture the battery casing.
    • Carefully peel the battery free from the casing.
Abschluss
To reassemble your device, follow instructions in the reverse order. Apply new Kapton Tape and apply extra solder as needed.
Justin Edwards
241 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G4, Harley Spring 2018 Mitglied von IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
3 Mitglieder
4 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 119
