Zum Hauptinhalt wechseln
DigiLand DL700D Motherboard Replacement
Was du brauchst
  1. DigiLand DL700D Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 DigiLand DL700D Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 DigiLand DL700D Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the device's back cover using the plastic opening tool.
  2. DigiLand DL700D Motherboard Replacement: Schritt 2, Bild 1 von 3 DigiLand DL700D Motherboard Replacement: Schritt 2, Bild 2 von 3 DigiLand DL700D Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the three pieces of adhesive placed over the edges of the battery.
  3. DigiLand DL700D Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the wifi antenna from the bottom of the battery.
  4. DigiLand DL700D Motherboard Replacement: Schritt 4, Bild 1 von 3 DigiLand DL700D Motherboard Replacement: Schritt 4, Bild 2 von 3 DigiLand DL700D Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Heat up the soldering iron, proceed to desolder and remove the battery connections.
  5. DigiLand DL700D Motherboard Replacement: Schritt 5, Bild 1 von 3 DigiLand DL700D Motherboard Replacement: Schritt 5, Bild 2 von 3 DigiLand DL700D Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the battery from the casing using a nylon spudger.
    • Be careful not to puncture the battery casing.
    • Carefully peel the battery free from the casing.
  6. DigiLand DL700D Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Desolder the WiFi antenna from the motherboard.
  7. DigiLand DL700D Motherboard Replacement: Schritt 7, Bild 1 von 3 DigiLand DL700D Motherboard Replacement: Schritt 7, Bild 2 von 3 DigiLand DL700D Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove 3 ribbon cables attached to the motherboard by lifting the plastic retainer, then pulling the cable out.
  8. DigiLand DL700D Motherboard Replacement: Schritt 8, Bild 1 von 2 DigiLand DL700D Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove adhesive attaching the motherboard to the casing.
  9. DigiLand DL700D Motherboard Replacement: Schritt 9, Bild 1 von 3 DigiLand DL700D Motherboard Replacement: Schritt 9, Bild 2 von 3 DigiLand DL700D Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Remove the three 2.5 mm Phillips #1 screws holding the motherboard to the case.
  10. DigiLand DL700D Motherboard Replacement: Schritt 10, Bild 1 von 3 DigiLand DL700D Motherboard Replacement: Schritt 10, Bild 2 von 3 DigiLand DL700D Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Remove motherboard from the case and replace.
Abschluss
To reassemble, follow these instructions in reverse order.
Justin Edwards
241 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G4, Harley Spring 2018 Mitglied von IUPUI, Team S3-G4, Harley Spring 2018
IUPUI-HARLEY-S18S3G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 259
