Einleitung
This guide will demonstrate how to replace to the DigiLand DL8006's motherboard. If your device is is experiencing frequent freezes and system lockups, and you have determined that it is not the fault of the RAM, power supply, or CPU, you may need to replace your motherboard. Make sure that you save your data on a separate device, as all the locally stored date will be removed when your motherboard is replaced.
Was du brauchst
Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
