Zum Hauptinhalt wechseln
DigiLand DL8006 Motherboard Replacement
Was du brauchst
  1. DigiLand DL8006 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 DigiLand DL8006 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
  2. DigiLand DL8006 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
  3. DigiLand DL8006 Motherboard Replacement: Schritt 3, Bild 1 von 3 DigiLand DL8006 Motherboard Replacement: Schritt 3, Bild 2 von 3 DigiLand DL8006 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the battery plug from the motherboard.
    • Fingers may be used to gently wiggle the connector out if it becomes stuck.
    • If battery wires are under the ribbon, Do Step #4 first.
  4. DigiLand DL8006 Motherboard Replacement: Schritt 4, Bild 1 von 2 DigiLand DL8006 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
  5. DigiLand DL8006 Motherboard Replacement: Schritt 5, Bild 1 von 2 DigiLand DL8006 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
    • Use tweezers to manipulate the connectors and ribbons to prevent damage.
  6. DigiLand DL8006 Motherboard Replacement: Schritt 6, Bild 1 von 3 DigiLand DL8006 Motherboard Replacement: Schritt 6, Bild 2 von 3 DigiLand DL8006 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
    • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
  7. DigiLand DL8006 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently remove the motherboard from the case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alec Trela
327 Reputation
2 Anleitungen geschrieben
University of Memphis, Team S2-G5, Kim Fall 2019 Mitglied von University of Memphis, Team S2-G5, Kim Fall 2019
UM-KIM-F19S2G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 174
