Einleitung
If one or both of the footswitches works inconsistently or not at all, refer to this guide.
Was du brauchst
Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
Pull firmly on the binder clips that are holding the footswitches in place to remove them.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
So what is the fix? Replacing both foot switches with new ones? Or removing them and reinstalling them will fix the problem of them not working at all? What’s Step 7? If you stop after completing Step 6 you now just have a casing without foot switches. What will fix the problem of them not working qt all after removing the foot switches?
