Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
If the input/output port is broken this guide will teach you how to remove the broken component for replacement.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks. Remove the four 8mm Phillips #0 screws located on the back panel.
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. Remove the back panel to expose the motherboard. Remove the back panel to expose the motherboard.
    • Remove the back panel to expose the motherboard.
  3. Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. Desolder the back of the motherboard where the damaged input/output port is located. Desolder the back of the motherboard where the damaged input/output port is located.
    • Desolder the back of the motherboard where the damaged input/output port is located.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Elijah Smith
696 Reputation
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 84
