Was du brauchst
Schritt 1 Digiland 10.1'' DL1016 Remove Backing
Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
Schritt 4 Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard
Achtung: Schritt 4 stammt von einer Anleitung, die derzeit bearbeitet wird.
Gently pull the wiring back.
Disconnect the black cable off the motherboard.
Remove the four 1.5mm Phillips #000 screws from the motherboard.
Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
Lift up the motherboard and place it somewhere that is clean and kept safe.
Once you have followed all steps simply replace the motherboard to fix your RAM
To reassemble your device, follow these instructions in reverse order. When following the Prerequisite Guide for Replacing the Power Button ONLY go to step 7.
