Was du brauchst
Schritt 1 Digiland 10.1'' DL1016 Remove Backing
Achtung: Die Schritte 1-2 stammen von einer Anleitung, die derzeit bearbeitet wird.
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
Schritt 4 Digiland 10.1'' DL1016 Remove Battery
Achtung: Schritt 4 stammt von einer Anleitung, die derzeit bearbeitet wird.
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
Once you remove the battery, simply replace the battery with a new one.
Ein Kommentar
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
