Zum Hauptinhalt wechseln
Digitac Jazz Ultratab C725 Charging Port Replacement
Was du brauchst
  1. Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: Schritt 1, Bild 3 von 3
    • Locate the four 3.5 mm Phillips head screws holding the silver back plate and the screen together. There are 2 screws on the top and another 2 screws on the bottom.
    • Remove all four screws with the Phillips #00 screwdriver.
    • Remove the screws with the least amount of force. The removal of the screw will be more difficult if thread damage occurs.
  2. Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 2, Bild 1 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 2, Bild 2 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Flip your device so that the long side without the buttons is facing you.
    • Insert the plastic opening tool between the silver back plate and the screen. From the corner of the device on either side, pry the seam of the device about 1 inch.
    • With the plastic opening tool, pry the screen apart from the back plate.
    • Keep prying the screen apart from the back plate until they are separated.
    • With the plastic opening tool, if necessary, pry apart the remaining seams of the device.
    • After the screen is loose, pull the screen towards you. Lift it to prevent damage to the buttons.
  3. Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 3, Bild 1 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 3, Bild 2 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 3, Bild 3 von 3
    • Locate the 3 black clips on the motherboard that hold the data cables./
    • Using the Spudger, pry the black clips up to a 90 degree angle./
    • Pull the data cables out once the clips are up to a 90 degree angle.
    • Repeat this for all 3 clips.
  4. Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 4, Bild 1 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 4, Bild 2 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Locate the two 4.0 mm Phillips head screws that are holding the motherboard in place.
    • Use the Phillips #00 screwdriver to remove both of the screws.
  5. Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 5, Bild 1 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 5, Bild 2 von 3 Digitac Jazz Ultratab C725 Charging Port Replacement: Schritt 5, Bild 3 von 3
    • The motherboard should now be loose.
    • To gain access to the charging port, flip the motherboard over.
    • Use the tweezers to pull the charging port off of the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 11-6, Blackwell Winter 2015 Mitglied von USF Tampa, Team 11-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G6
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 441
