Einleitung
This guide will be showing you how to replace the front camera that is 0.3 MP and the rear camera that is 2.0 MP. Be sure to carefully remove the camera to avoid damaging the device.
Was du brauchst
Insert spudger in the slot below the micro SD card.
With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
Locate and unplug the flat-top connector from the motherboard..
To unplug the connector go under it with either side of the spudger and lift up.
To remove the camera, simply use the pointed end of the spudger and insert it in the corner and gently lift.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
