Einleitung
This guide will be showing you how to replace the LCD screen. Be sure to carefully remove components to avoid damaging the device.
Was du brauchst
Insert spudger in the slot below the micro SD card
With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
Use prying tools to carefully break the adhesive under the battery
Locate the flat-top connector. Go under it with the spudger and simply lift up.
To remove the camera, simply use the pointed end of the spudger and insert it in the corner and gently lift.
Remove two 3.51mm screws located on the bottom corners of the device with your Phillips #00 Screwdriver.
Carefully lift the casing and pull back the tape along with the soldered wire.
Remove the two 3.51mm screws that are located on the top corners of the device with the same phillips screwdriver..
Next, unplug the ZIF connector and slide it out with the pointed side of the spudger.
To unclip the connector, go under the black tap and simply lift with your finger nail or spudger.
Watch out for the ZIF connector!
To remove the motherboard, grab the component on the top left and gently lift. Be careful with the clip holding the motherboard.
Now that every component is removed, use the flat side of the spudger and insert it on the bottom of the screen.
Gently move along the edges to lift the screen.
