Zum Hauptinhalt wechseln
Digital2 D2-912 Motherboard Replacement
Was du brauchst
  1. Digital2 D2-912 Motherboard Replacement, External Cover: Schritt 1, Bild 1 von 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Motherboard Replacement: Schritt 2, Bild 1 von 2 Digital2 D2-912 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
    • Remove the wires shown in the image, using a soldering iron and solder sucker.
    • By removing the wires, you are detaching the battery and speaker from the motherboard.
  4. Digital2 D2-912 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the three screws from motherboard.
  5. Digital2 D2-912 Motherboard Replacement: Schritt 5, Bild 1 von 2 Digital2 D2-912 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Detach the capacitive touch controller from the motherboard.
    • Carefully pry the narrow black connector upward to release the ribbon.
    • Remove the ribbon from the connector.
  6. Digital2 D2-912 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Locate the camera found in the image.
    • Carefully pry the black connector upward to release ribbon.
    • Remove the black tape to release the camera from the motherboard.
    • Remove and replace the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jason Wignot
322 Reputation
3 Anleitungen geschrieben
IUPUI, Team 1-1, Harley Fall 2015 Mitglied von IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 379
