Zum Hauptinhalt wechseln
Digital2 Platinum Pad 9 External Cover Replacement
Was du brauchst
  1. Digital2 Platinum Pad 9 External Cover Replacement, External Cover: Schritt 1, Bild 1 von 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 External Cover Replacement: Schritt 2, Bild 1 von 2 Digital2 Platinum Pad 9 External Cover Replacement: Schritt 2, Bild 2 von 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 External Cover Replacement: Schritt 3, Bild 1 von 2 Digital2 Platinum Pad 9 External Cover Replacement: Schritt 3, Bild 2 von 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
Abschluss
UMass Dartmouth, Team 5-6, Landers Spring 2016 Mitglied von UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 291
