Zum Hauptinhalt wechseln
Dirt Devil Gator Motor Replacement
Was du brauchst
  1. Dirt Devil Gator Motor Replacement, Motor: Schritt 1, Bild 1 von 1
    • Press the button found at the top of the vacuum to separate the suction cup and the motor halves.
  2. Dirt Devil Gator Motor Replacement: Schritt 2, Bild 1 von 3 Dirt Devil Gator Motor Replacement: Schritt 2, Bild 2 von 3 Dirt Devil Gator Motor Replacement: Schritt 2, Bild 3 von 3
    • Pull apart the two halves to obtain the back half and set the front half aside
  3. Dirt Devil Gator Motor Replacement: Schritt 3, Bild 1 von 3 Dirt Devil Gator Motor Replacement: Schritt 3, Bild 2 von 3 Dirt Devil Gator Motor Replacement: Schritt 3, Bild 3 von 3
    • Unscrew each of the 13 mm screws with the micro screwdriver.
    • Once unscrewed, pull the case of the Dirt Devil Gator apart.
  4. Dirt Devil Gator Motor Replacement: Schritt 4, Bild 1 von 3 Dirt Devil Gator Motor Replacement: Schritt 4, Bild 2 von 3 Dirt Devil Gator Motor Replacement: Schritt 4, Bild 3 von 3
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
  5. Dirt Devil Gator Motor Replacement: Schritt 5, Bild 1 von 1
    • Remove the motor from the Dirt Devil Gator exterior by pulling slightly on the white socket.
    • Replace it with a new motor by fitting the motor back into its socket.
    • Be cautious when handling the batteries and wires.
    • Keep the grey on-off switch in the "off" position to ensure a quick reassembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 419
