Zum Hauptinhalt wechseln
Dirt Devil Scorpion Quick Flip Filter Adapter Replacement
  1. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: Schritt 1, Bild 1 von 2 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: Schritt 1, Bild 2 von 2
    • First, press the button on the handle of the vacuum to separate the two halves.
    • The button triggers a release mechanism, detaching the front half from the back of the vacuum.
  2. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: Schritt 2, Bild 1 von 1
    • Once the front half has been separated from the back half, locate the filter adapter.
    • The filter adapter is attached to the filter, locating the filter in this step will sufficiently locate the filter adapter.
    • Grasp the filter and adapter. Pull them out together.
  3. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: Schritt 3, Bild 1 von 2 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: Schritt 3, Bild 2 von 2
    • Rotate the filter counterclockwise to remove it from the filter adapter.
    • Once the filter adapter has been removed from the filter, replace it.
Abschluss
Joseph Warner
201 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G1, Wilson Fall 2017 Mitglied von IUPUI, Team S1-G1, Wilson Fall 2017
IUPUI-WILSON-F17S1G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 507
