Einleitung
This guide will allow readers to replace the filter adapter on their Dirt Devil Scorpion Quick Flip hand vacuum. The primary reasons to change a filter adapter include improper suction or visible damage to the current filter adapter.
First, press the button on the handle of the vacuum to separate the two halves.
The button triggers a release mechanism, detaching the front half from the back of the vacuum.
Once the front half has been separated from the back half, locate the filter adapter.
The filter adapter is attached to the filter, locating the filter in this step will sufficiently locate the filter adapter.
Grasp the filter and adapter. Pull them out together.
Rotate the filter counterclockwise to remove it from the filter adapter.
Once the filter adapter has been removed from the filter, replace it.
