Einleitung
Use this guide to replace the brush roller on your Dirt Devil Vibe vacuum when the brush on your vacuum stops spinning or spins too slowly. You will need a #0 phillips-head screwdriver to complete this replacement. Make sure the vacuum is unplugged before starting the replacement process for safety purposes. Make sure to keep track of all screws that will be removed during the replacement process.
Was du brauchst
After removing all of the screws pull the vacuum's black cover up to remove it.
