Zum Hauptinhalt wechseln
Disassembling 8BitDo Pro 2 Wired Joystick Board
Was du brauchst
  1. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove R2 and L2 pads: Schritt 1, Bild 1 von 2 Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove R2 and L2 pads: Schritt 1, Bild 2 von 2
    • Remove both pads by pushing them up.
    Frag FixBot
  2. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove T6 Screws: Schritt 2, Bild 1 von 1
    • Remove both Torx T6 screws from the back.
    Frag FixBot
  3. Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: Schritt 3, Bild 1 von 3 Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: Schritt 3, Bild 2 von 3 Disassembling 8BitDo Pro 2 Wired Joystick Board, Open the controller: Schritt 3, Bild 3 von 3
    • With an opening pick, detach the seven clips holding the faceplate. Start from the sides, towards the bottom.
    • Detach the remaining clips by carefully raising the faceplate away from the clips.
    • A flex cable joins both plates.
    • Move the faceplate to the side.
    Frag FixBot
  4. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the flex cable: Schritt 4, Bild 1 von 1
    • Push the sides of the connector away from it to free the cable.
    Frag FixBot
  5. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the #0 screws: Schritt 5, Bild 1 von 1
    • Remove the 8 screws using a Phillips #0 screwdriver.
    • You can remove the joystick caps by lifting them.
    Frag FixBot
  6. Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the board: Schritt 6, Bild 1 von 2 Disassembling 8BitDo Pro 2 Wired Joystick Board, Remove the board: Schritt 6, Bild 2 von 2
    • Slowly lift the board from the controller. Make sure to lift both rumble motors as well.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 31
Letzte 30 Tage: 144
Insgesamt: 1,256
