Was du brauchst
Screws List:
4 x "Torx 6" 7mm screws
6 x "Phillips 1" 10mm screws
10 x "Phillips 1" 5mm screws
1. Open the back lid
2. Remove battery
Remove 4 screws:
2 screws in handles
2 screws under the label
3. Unclip trigger's covers
JFYI: My label is not original
Using pry tool to split two parts. Start from handles.
Open to the right carefully - there is a ribbon cable
Slide ribbon cable lock to the right, then unplug ribbon cable
Remove 9 x "Phillips 1" 5mm screws
Remove stick caps
Eject vibration motors from slots in handles
Eject circuit board
Remove 6 x "Torx 6" 10mm screws
Remove 1 x "Phillips 1" 5mm screw
Remove circuitboard with plastic attachments
Deattach buttons, rubber pads and plastics aligners.
While assembling back, make sure, ABXY rubber pad cut angle is on top.
Unclip plasctic attachments with buttons and triggers. They are connected by pressure alone to the PCB
