Einleitung
Ported from insidemylaptop.com.
Note: older variants of the K501U model ship with a different board layout, only one fan, and without an M.2 drive installed.
Was du brauchst
Remove the four 10.7mm-long screws along the top edge.
Remove the two 6.7mm-long screws along the sides.
Remove the four 4.7mm-long screws along the bottom edge.
The bottom cover is held in place by plastic tabs along the outside edges. Using a plastic pry tool, carefully separate the bottom cover from the palmrest assembly and remove it.
In order to unlock the battery connector you’ll have to slide the metal bracket to the shown direction.
You can find a new replacement battery using the part number printed on the original battery. I would recommend using a genuine Asus battery, not a third-party replacement. Replacement battery model B31N1429.
Asus K501U motherboard has only one memory slot. Some memory is built into the motherboard. You can access the available slot if you remove the metal cover. You can install up to 8GB DDR3-12800 SODIMM RAM module into this slot.
Remove four 4.7mm-long screws from the hard drive caddy and remove the caddy. This laptop came with a m.2 solid state drive so there is no regular 2.5″ hard drive installed.
Remove one screw securing the solid state drive and pull the drive out. This is m.2 SATA III solid state drive (not NVMe).
Remove three screws securing the right fan.
Disconnect fan cable from the motherboard.
Remove three screws securing the left fan.
The USB audio board is mounted under the right hinge.
Remove three screws from the right hinge. Remove one screw from the board.
Disconnect the USB audio board cable (color-coded in green).
Disconnect the right speaker cable (color-coded in yellow).
Unlock the connector first by lifting up the locking tab.
After that pull the cable out.
Remove one 4.7mm-long screw securing the wireless card.
Pull out the wireless card in the direction shown.
Eine weitere Person hat diese Anleitung absolviert.
