Zum Hauptinhalt wechseln
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
Was du brauchst
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: Schritt 1, Bild 1 von 2 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: Schritt 1, Bild 2 von 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: Schritt 2, Bild 1 von 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: Schritt 2, Bild 2 von 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: Schritt 2, Bild 3 von 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: Schritt 3, Bild 1 von 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Efe Guldogan
860 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 14-23, Meier Fall 2015 Mitglied von USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 36
Insgesamt: 13,616
