Einleitung
Removing the cover of the Apple IIc is the precursor to any repair on a computer and it allows you to view the eternal workings of this device.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
6 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
