Zum Hauptinhalt wechseln
Disassembling Asus W2W-A1 Front Panel
Was du brauchst
  1. Disassembling Asus W2W-A1 Front Panel, Keyboard: Schritt 1, Bild 1 von 3 Disassembling Asus W2W-A1 Front Panel, Keyboard: Schritt 1, Bild 2 von 3 Disassembling Asus W2W-A1 Front Panel, Keyboard: Schritt 1, Bild 3 von 3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
    Frag FixBot
  2. Disassembling Asus W2W-A1 Front Panel: Schritt 2, Bild 1 von 1
    • Remove the panel above the keyboard with a plastic spudger.
    Frag FixBot
  3. Disassembling Asus W2W-A1 Front Panel: Schritt 3, Bild 1 von 1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
    Frag FixBot
  4. Disassembling Asus W2W-A1 Front Panel: Schritt 4, Bild 1 von 2 Disassembling Asus W2W-A1 Front Panel: Schritt 4, Bild 2 von 2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
    Frag FixBot
  5. Disassembling Asus W2W-A1 Front Panel, Front Panel: Schritt 5, Bild 1 von 1
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
    Frag FixBot
Abschluss
Cal Poly, Team 13-29, Maness Spring 2014 Mitglied von Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 45
Insgesamt: 576
