Zum Hauptinhalt wechseln
Disassembling Beats Pill 1.0
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Disassembling Beats Pill 1.0, Removing the Case Screws: Schritt 1, Bild 1 von 3 Disassembling Beats Pill 1.0, Removing the Case Screws: Schritt 1, Bild 2 von 3 Disassembling Beats Pill 1.0, Removing the Case Screws: Schritt 1, Bild 3 von 3
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
  2. Disassembling Beats Pill 1.0, Removing Center Cover: Schritt 2, Bild 1 von 3 Disassembling Beats Pill 1.0, Removing Center Cover: Schritt 2, Bild 2 von 3 Disassembling Beats Pill 1.0, Removing Center Cover: Schritt 2, Bild 3 von 3
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
  3. Disassembling Beats Pill 1.0, Separate the Device: Schritt 3, Bild 1 von 3 Disassembling Beats Pill 1.0, Separate the Device: Schritt 3, Bild 2 von 3 Disassembling Beats Pill 1.0, Separate the Device: Schritt 3, Bild 3 von 3
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Disassembling Beats Pill 1.0, Disconnect Speaker Wiring: Schritt 4, Bild 1 von 2 Disassembling Beats Pill 1.0, Disconnect Speaker Wiring: Schritt 4, Bild 2 von 2
    • Carefully remove the yellow, red, black, and white wires from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Disassembling Beats Pill 1.0, Disconnect NFC Sensor Wiring: Schritt 5, Bild 1 von 2 Disassembling Beats Pill 1.0, Disconnect NFC Sensor Wiring: Schritt 5, Bild 2 von 2
    • Carefully remove the black and red NFC sensor wires.
  6. Disassembling Beats Pill 1.0, Disconnect Control Wiring: Schritt 6, Bild 1 von 2 Disassembling Beats Pill 1.0, Disconnect Control Wiring: Schritt 6, Bild 2 von 2
    • Carefully remove the control cables (4 black, 1 red).
Abschluss
To reassemble your device, simply follow the disassembly guide in reverse. If you have questions or concerns about the disassembly of your device, please see the device page or troubleshooting page for the Beats Pill 1.0 for more information.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 5-4, Blackwell Fall 2015 Mitglied von USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 12
Insgesamt: 4,180
