Einleitung
As a first step to clean, maintain, or install new parts (excluding the blender blades) for the Black and Decker BL3000S the blender base must be taken apart. This guide will provide step by step instructions of how to perform this task.
  1. Before disassembling the blender base, make sure the blender disconnected from any power outlet. Lift the jar straight up from the base without tilting the jar.
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver. This provides access to the base screws beneath.
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  5. Remove the following screws that secure the top and  bottom halves of the base.
    • Remove the following screws that secure the top and bottom halves of the base.
      • One 1/4 Phillips screw
      • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  6. Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Andrew
170 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 6-34, Regan Fall 2012 Mitglied von Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 56
Insgesamt: 3,931
