Einleitung
This guide will show you how to open your drill so that you can fix any problems that require you to open it up and possibly remove or replace parts. This guide is prerequisite only.
Was du brauchst
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
3 weitere Personen haben diese Anleitung absolviert.
