Zum Hauptinhalt wechseln
Einleitung
Determining a problem with the keypad or circuitry begins with removing the keyboard from the Blackberry Pearl.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Ensure the bottom piece is fully detached by gently prying it loose with the plastic prying tool. Take the plastic prying tool and gently work around the keypad. When loosened, simply lift the keypad up and off.
    • Ensure the bottom piece is fully detached by gently prying it loose with the plastic prying tool.
    • Take the plastic prying tool and gently work around the keypad.
    • When loosened, simply lift the keypad up and off.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Once the keyboard is loosened, the button on the side of the phone may also release.
    • Once the keyboard is loosened, the button on the side of the phone may also release.
Abschluss
Ashley
306 Reputation
3 Anleitungen geschrieben
SUNY Cortland, Team 1-5, Getto Spring 2013 Mitglied von SUNY Cortland, Team 1-5, Getto Spring 2013
SUNYCORT-GETTO-S13S1G5
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 528
