Zum Hauptinhalt wechseln
Disassembling Breville BKC600XL Coffee Brewer Head
Was du brauchst
  1. Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: Schritt 1, Bild 1 von 3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: Schritt 1, Bild 2 von 3 Disassembling Breville BKC600XL Coffee Brewer Head, "Bottom" Black Shell Piece: Schritt 1, Bild 3 von 3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
    Frag FixBot
    Kommentar hinzufügen
  2. Disassembling Breville BKC600XL Coffee Brewer Head, "Top" Black Shell Piece: Schritt 2, Bild 1 von 1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
    Frag FixBot
  3. Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: Schritt 3, Bild 1 von 3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: Schritt 3, Bild 2 von 3 Disassembling Breville BKC600XL Coffee Brewer Head, Silver Casing: Schritt 3, Bild 3 von 3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 1-3, Propen Fall 2012 Mitglied von Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 Mitglieder
24 Anleitungen geschrieben
2 Kommentare zur Anleitung
Thanks so much for posting this! I was ready to throw my Breville out the window! Step three highlighted the closing mechanism and I was able to easily repair my machine!!
Thanks
acaltab - Antwort Teilen
Does anyone know the name of the orange piece? And where I can get just that piece?
Ursula Nawab - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 43
Insgesamt: 4,829
