Zum Hauptinhalt wechseln
Disassembling Canon EOS Rebel XS Front Cover
Was du brauchst
  1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: Schritt 1, Bild 1 von 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Front Cover: Schritt 2, Bild 1 von 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: Schritt 3, Bild 1 von 1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Front Cover: Schritt 4, Bild 1 von 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Daniel Bussone
1.260 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 3-41, Regan Winter 2011 Mitglied von Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Mitglieder
21 Anleitungen geschrieben
3 Kommentare
This should be labelled: Easy.
tjt263 - Antwort
Okay, there are several steps missing.
tjt263 - Antwort
This is impossible to follow, there must be several things missing here
Fredrik Sjöborg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 5,352
