Einleitung
This guide will show you how to disassemble the back and side panel of the printer.
Was du brauchst
Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
Remove the blue lever from its slot by pushing it back and twisting clockwise.
Close the scanner compartment and cover.
Flip the printer over so that the bottom of the printer is facing you.
Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
Use the plastic opening tool to loosen the side panel from the bottom of the printer.
6 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Good job!!!!
Where is the rest of disassembly?
