Einleitung
This guide will show you how to disassemble the back and side panel of the printer.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the following two Phillips screws:
Two 7.85 mm Phillips #1 screws
After opening up the scanner compartment, make sure the blue lever locks into place, keeping the compartment open.
Push the blue lever back while twisting it clockwise in order to remove the lever from its slot.
After removing the lever, close the scanner compartment and the scanner cover.
Flip the printer so that you are facing the underside.
Use the plastic opening tool to remove the corner of the side panel from the pin.
Plastic pin.
Using the plastic opening tool, remove the side panel by loosening it from the bottom of the printer.
5 weitere Nutzer haben diese Anleitung absolviert.
