Einleitung
Use this guide to remove the AV port and logic board.
Was du brauchst
Remove 2 screws from each side of the camera (4 total, 0.102 in).
Remove 2 screws from the bottom on the camera (0.138 in).
Remove the top-left screw above the LCD screen (0.100 in).
Remove the C-shaped plate from the side of the LCD screen.
Remove the screw from the top-right of the LCD screen (0.098 in).
Remove the L-shaped bar from the right of the LCD screen.
Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
Use the tweezers to lift this ribbon.
Use the tweezers to gently peel this ribbon from the one underneath it.
Use the spudger to remove the lens ribbon from the circuit board.
Use the spudger to lift the ribbon.
Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
Use spudger to carefully lift the LED light off the upper-left corner of the lens.
Remove screw from top-right of logic board (0.102 in).
Remove screw on the silver plate (0.102 in).
Using the spudger, disconnect the ribbon cable located on the top of the logic board.
Remove the remaining screw (0.102 in) located on the camera strap piece.
The camera strap piece and the av port/battery/memory card assembly can now be removed.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
