Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Remove the back cover before removing LCD display.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove one 2.25mm screw on the bottom.
    • Remove one 2.25mm screw on the bottom.
  2. Remove two 2.25mm screws on the right side looking from the front.
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Remove one 4.7mm screw on the side with the AV output.
    • Remove one 4.7mm screw on the side with the AV output.
  4. Pull off the back cover.
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  6. Remove 2 2.4mm screws on bottom.
    • Remove 2 2.4mm screws on bottom.
  7. Follow the small data cable to where it connects to the camera.
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  8. Gently lift LCD display off.
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  9. Follow the larger cable to where it connects to the camera.
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
  10. Pry the LCD display out from the four metal clamps.
    • Pry the LCD display out from the four metal clamps.
  11. To remove the LCD, peel the larger data cable off from the frame.
    • To remove the LCD, peel the larger data cable off from the frame.
    • The LCD is glued by its data cable to the back of the LCD frame.
Abschluss
Jeremy Rabaino
135 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 20-9, Maness Fall 2010 Mitglied von Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 2,550
