Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The LCD display can be removed and replaced if it is cracked or broken.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen. Remove the 2 screws (4.08 mm) on the other side.  One is located under the rubber USB flap. Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
    • Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
    • Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Slowly pull the back cover of the camera.
  2. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  3. Remove the screws (2.88 mm) at the top right corner and bottom left corner of the LCD screen. Disconnect the ribbons connecting the screen to the camera. Lift off the screen.
    • Remove the screws (2.88 mm) at the top right corner and bottom left corner of the LCD screen.
    • Disconnect the ribbons connecting the screen to the camera.
    • Lift off the screen.
Abschluss
Ben Tupas
317 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 13-3, Forte Winter 2011 Mitglied von Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Mitglieder
8 Anleitungen geschrieben
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 2,194
