Zum Hauptinhalt wechseln
Disassembling Chef's Choice M115 Case
Was du brauchst
  1. Disassembling Chef's Choice M115 Case, Case: Schritt 1, Bild 1 von 2 Disassembling Chef's Choice M115 Case, Case: Schritt 1, Bild 2 von 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Disassembling Chef's Choice M115 Case: Schritt 2, Bild 1 von 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Disassembling Chef's Choice M115 Case: Schritt 3, Bild 1 von 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Disassembling Chef's Choice M115 Case: Schritt 4, Bild 1 von 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team 3-3, Harley Fall 2015 Mitglied von IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 20
Letzte 30 Tage: 39
Insgesamt: 1,680
