Einleitung
Before accessing the screen itself or the built in webcam, you must remove the display assembly from the base.
Was du brauchst
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Unscrew all the corner screws. There are four total, one under each rubber pad.
Remove the three screws in the silver tabs at the back of the keyboard.
Lift the keyboard away from the laptop.
Pry up the top plastic cover using a spudger.
These two tabs under the screen need to be pushed in with a spudger.
Remove the four screws that keep the bottom of the hinges attached to the base.
Pry off the top plastic cover of the display assembly.
The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
