Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Before accessing the screen itself or the built in webcam, you must remove the display assembly from the base.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Find the battery and the battery tabs located on the bottom of the Compaq Mini. Find the battery and the battery tabs located on the bottom of the Compaq Mini.
    • Find the battery and the battery tabs located on the bottom of the Compaq Mini.
  2. Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out. Push the tabs inward and slide the battery out.
    • Push the tabs inward and slide the battery out.
  3. Unscrew the two screws on the bottom of the laptop covering the memory compartment. The screws are attached to the panel.
    • Unscrew the two screws on the bottom of the laptop covering the memory compartment.
    • The screws are attached to the panel.
  4. Push out side tabs.
    • Push out side tabs.
  5. Remove the rubber pads located on the corners of your Compaq Mini. There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  7. Unscrew all the corner screws. There are four total, one under each rubber pad. Unscrew all the corner screws. There are four total, one under each rubber pad.
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  8. Unscrew the screw for the bottom case located in the RAM compartment. Unscrew the screw for the bottom case located in the RAM compartment.
    • Unscrew the screw for the bottom case located in the RAM compartment.
  9. Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen. Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
    • Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
  10. Remove the three screws.
    • Remove the three screws.
  11. Pull up on the tab. Pull up on the tab.
    • Pull up on the tab.
  12. Remove the eight screws from the plastic top cover.
    • Remove the eight screws from the plastic top cover.
  13. Pry up the top plastic cover using a spudger. Under the screen there are two tabs that need to be pushed in. Under the screen there are two tabs that need to be pushed in.
    • Pry up the top plastic cover using a spudger.
    • Under the screen there are two tabs that need to be pushed in.
  14. Careful lifting up the cover because the track pad is still attached. Remove the cable by pulling it up.
    • Careful lifting up the cover because the track pad is still attached.
    • Remove the cable by pulling it up.
  15. Take out the four screws that keep the bottom of the hinges attached to the base. Take out the four screws that keep the bottom of the hinges attached to the base. Take out the four screws that keep the bottom of the hinges attached to the base.
    • Take out the four screws that keep the bottom of the hinges attached to the base.
  16. Pry off the top plastic cover of the display assembly. Note: There is adhesive tape holding the cover on. Note: The spudger may go all the way through to the screen-side of the cover. This is ok and will not damage anything.
    • Pry off the top plastic cover of the display assembly.
    • Note: There is adhesive tape holding the cover on.
    • Note: The spudger may go all the way through to the screen-side of the cover. This is ok and will not damage anything.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
alea
1.366 Reputation
14 Anleitungen geschrieben
Cal Poly, Team 22-2, Maness Fall 2010 Mitglied von Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Mitglieder
20 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 7,210
