Einleitung
Sticky keys? Simply just want to get rid of your keyboard? Here's how.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Find the battery and the battery tabs located on the bottom of the Compaq Mini.
Find and remove the two screws on the bottom of your Compaq Mini covering the memory compartment.
Unscrew all the corner screws. There are four total, one under each rubber pad.
Remove the three screws in the silver tabs at the back of the keyboard. The red circles show where they are located at the back of the base under the screen.
4 weitere Nutzer haben diese Anleitung absolviert.
3 Kommentare
hi, steps 5 and 6 are not needed. not sure about removing RAM either. If I look on my removed keyboard, all I see are three places for screws - those located nearby battery socket.
I think steps 3,4,5,6,7 are not needed! The essential problem in removing the keyboard is not shown: how to lift the keyboard! Use the flat side or back of a screwdriver to push the metal strips shown in step 8 up (in the direction of the keyboard) to lift the keyboard. Put your fingers under the edge of the keyboard and pull gently but firmly. There is some resistance of the holding cover.
Thank you so much for the link!
Alex -
